Well I started back at it today guys sorry for not keeping thread updated, I haven't been feeling good this last couple weeks..Well I got the rocker pannel carfuly cut out and removed all the rusted inner rocker panel suport out..I also cleaned all the surface rust and rusty scale off the outer side of frame rail and put a coat of black paint on the outer section of the frame rail, once the sheet metal support for the rocker panel is installed you cant get to the outer section of the frame which is why I painted the outside..I also cut the sheet metal for the inner rocker support and i currently have it clamped in to check for fit..Once the fit is good i will spot weld it in along with rocker pannel..I have the driver side floor pan mostly cut out once I finish the rocker area on driver side, I will finnish cutting pass side floor out and fix what ever needs fixed with pass side rocker and once thats done I can box in the inner frame rails and start the custom floor
