SignUp Now!what is your backspaceheres mine
325/50-15 on 15x10rim
rolled lips
outer frame notched ( tsm legal)
next set wont be 325's , going to 295's.. so much easier, no notch needed but with the notch i'll be able to move 295's in and drop the car
For this tire
pacecarta said:5" with a 3/8 spacer (4 5/8 BS)
Donnie, no wonder why you have to ''cut everything'' to make them fit...you don't have enough rear spacing on these wheels! Jack just sold me some 15''x10'' wheels but with a rear spacing of 5.5'' ! ... Right now, I'm using these wheels with a 1/2'' spacer until this spring when Brian will do a frame notch. Then when the notch is done, I'll just have to get rid of the spacer and the wheels will fit just fine.That's why I have to do a lot more work. I got 3" backspace on 10" rims. I'm cutting everything to fit. I won't know exactly how I'm gonna go about this until I have my other frame in front of me.
I know this already Claude, but Im running the VECTORS. I have stock alum T Type wheels up front, and my 10's look exactly the same. I did not want the 8.5's, I wanted the 10's and I was prepared to do the extra work. I have never seen another car with the 10's on it. It will look awesome. They are at the Chrome Shop right now getting the works. Wait til you see them...Donnie, no wonder why you have to ''cut everything'' to make them fit...you don't have enough rear spacing on these wheels! Jack just sold me some 15''x10'' wheels but with a rear spacing of 5.5'' ! ... Right now, I'm using these wheels with a 1/2'' spacer until this spring when Brian will do a frame notch. Then when the notch is done, I'll just have to get rid of the spacer and the wheels will fit just fine.
Claude.![]()
6togo said:Been looking at some notch work done on the Regals i think my goal would be 315 DR's i will be running 18" wheels due to the big brakes. so the question is will a 18x11" wheel with a 315 DR fit in the wheel well once notched? I have half the wheel well lip shaved and I'm not opposed to widening the wheel tubs some but dont want to lose the back seat.
v6togo said:With 3" backspacing wont you have to narrow the frame? your drums are going to hit the frame.. I have the 15x9 prostars with 4.5 b.s that puts the wheel in the center of the the wheelwell.I run a 275/50 15 the car is lowered 2" and everything fits in the wheelwell. section width is 11.75. I'm not to far from you coach you can try them on..
Adam
