This Motor was completely redone and has 150 breakin miles on it------
--109 Block +.020"
--2 Billet Center Main caps with ARP studs
--Billet Roller cam setup 206-206 Duration 520-520 Lift
--Total Seal Gapless Top ring set
--Federal Mogul Hyper Pistons
--10-10 Turbo Crank
--H-series Rod and Main bearings
--Durabond coated cam bearings
--Rods Reconditioned and Beams are Polished with ARP bolts
--ARP head studs
--New ported front timing cover with booster plate and TA adjustable oil regulator
--Cloyes .005" under timing chain
--Fully ported&polished 8445 Heads Flowed 219 Intake 189 Exhaust with new Stainless 1.77" intake valves setup with 135 lb. roller springs
--New Harland Sharp roller rockers 1.5 ratio
--Cometic head gaskets
--Ported Intake to match
--Comes complete pan to intake with all stainless hardware: water pump, crank sensor, knock sensor, motor mounts and cam sensor all new with 150 miles!!!!!!!!!!!!
I accept Paypal!! $4200 OBO Plus Shipping-- Drop in and GO!!! 443-907-2079
--109 Block +.020"
--10-10 Turbo Crank
--ARP head studs
