jhanson1750
just a 10th quicker
- Apr 24, 2005
SignUp Now!Today 11:44 AM
ttypewhite I would say, go with your gut reaction on this. Get rid of the lockwire. But keep in mind, as soon as you mill the heads you might have to use a different intake gasket to take up the slack that the milling has done. Your intake may or may not line up well when its done. So have the upper plenum off and look down the ports on the lower intake to make sure all is good before you button it down.
Today 12:25 PM
J-B Racing This is a topic that I spoke about many times in the past. Fel pro a while back made a mistake in the instructions when they asked to make Grooves .008`` deep. Now on the New 1007`s they recommend to make the Grooves .012`` Deep. Because if this mistake, the Gakste does not make a confortable Bond and causes Water Seepage between the Head and the Block.
Joe
I had the machine shop check out the heads but I don't know what the depth of the cut was. The heads were cut when I bought them. Jon Hanson
Today 12:59 PM
BlackBandit What are your performance goals. IMO I would lose the grooves. I had receiver grooves in my heads and had them machined off. I'm not going to get out of the 11's with this engine though and probably won't go faster than an 11.5. I also figured if I wanted to use the heads in a faster engine I could just go to a cometic. Allot of guys are running pretty fast on those.
Well I got is to quit leaking!!I used some of the better looking stuff at the local auto parts store (no big chuncks or flakes in the can) and followed the directions on the back. "Flush coolant system (not needed),drain the radiator, mix product with 3 quarts of warm water and pour into radiator, run engine for 20-30 mins, DO NOT RACE ENGINE OR DRIVE THE AUTOMOBILE!! Drain the cooling system and let sit for 24 hours with the system open. (no rad cap and drain open) I also pulled both rad hoses to let it "breath" a little better. The next day (Monday) I put the cooling system pressure tester back on and she holds 14lbs perfectly. The next thing is to install valve seals on the exhaust sides of both heads while retorquing. Then install the catalitic (sp?) converter and see if she will pass smog. If so swap out for the 3" DP and build the test pipe for it. THEN start tuning!!!!:biggrin:
Guys thanks for all the replies and support. Jon Hanson
Ps. Does anyone think I should pick up the tabs anyway and throw them in just for insurance??
