well i replaced the drivers side cv axle and have been having problems it being to tight, the only thing i changed was the axle, no hub bearings, and it was real tight going on the steering knuckle, so i drove it and heard a loud clunking noise, so i replaced the axle again, and still tight but not so much clunking noise, so i ordered 2 more axles,and i replace it again, and this time replace the hub bearings, and it went on alot better no tightness, plus i even looked at both hub bearings, for comparision, and did see a little difference in the hub bearings, where the splines get close to the drive shaft, but drove it down the road, and can hear the rotor making whinning noise, like its touching and not, could i have messed a rotor, or the wheel, plus its still making a clunking noise, i cant hear it or feel it in the passenger side, since i didnt mess with that side, i have posted before about this, but seems nobody has that problem, im
