Replacing front upper & lower control arms and would like to get new factory hardware. I have the following numbers for the upper splined bolts & nuts:
Bolt - 461854
Nut - 11516073
Just need the lower bolt & nut P/N. Any help appreciated.
drill the holes in the frame out to 1/2", use S10 bushings, and use some 1/2" grade 8 bolts in whatever length they are from the local farm supply store that sells in bulk. don't forget the lock washers and nuts...
