Ok, this is really starting to suck! Talked to Brian at GBody he told me that he is running moog 5662 springs from a 87 Iroc thier spring rate is a little heavy but would work great. I ordered them yesterday installed them today now i'm in worse shape than i was before i can't even move the car because of wheel rub
I reconnected everything without the spring and lowered the car with my floor jack to 26.50" the perfect ride height and measured the distance between the upper and lower spring pearch which was 11" which should be the proper compressed height for the 5606 spring. is it possible to have that many wrong springs even with the 5662 or the 5658 the ride height should be 10.75" which would be ok. Oh by the way I'm really good at switching springs if someone needs help:smile:
