Up for Sale is my 1992 E39A Mitsubishi Galant VR-4 #995/1000
Turbo, All Wheel Drive, All Wheel Steering, 5-Speed, Black Leather.
It is an option A71 model [1 of 88 ever made, RARE!] meaning that it is 92' Belize Green, has a sunroof, and a factory cassette radio with EQ/input (which I still have)
Some of you might have seen it at the Shamrods Car Shows
The car is located in Bourne, MA.
more pictures here: BessoVR4's photos and albums on webshots
Modifications
Engine:
-JDM 4G63 Engine w/ Cyclone Intake Manifold
-3G #482 MAF and IceMan Connector Harness
-K&N RT-4610 4.5" Titanium air Filter
-Vibrant aluminum 3G MAS Adapter
-560cc Denso EVO VIII Injectors (Flow Tested by Cruizin Performance)
new OEM Isolators and Fuel Filter also installed
-Polished Throttle body elbow and replaced newer JDM Throttle Body
-Magnacore 10mm Spark plug wires and NGK BSE7's with a .029" gap
-RRE CNC'd Anodized Black Spark Plug Wire Cover
-Joe P. MBC with ZX Uprgrade
-External Oil cooler
-Mofugas 2 1/2" stainless Turbo Back exhaust with a Magnaflow single tip muffler
Electronics / ECU / Fuel Management:
-Keydiver Stage 3 Dual Image EPROM
socketed by: PowerPlay (capacitors have also been replaced)
-Cyclone canister on purge valve
-Palm III-C running MMCD w. Auto on ALDL OBD-I cable
-Cruise controle deleted
-Apex'i Black SAFC-II Tuned by KTR Performance
-UltraTimer JDM Turbo Timer in the ashtray
Drivetrain/Suspension:
-Whiteline 26mm rear Sway bar (not installed but comes with car)
-Replaced most 4WS Lines and used Mobil-1 DOT 3 brake Fluid
-MD733623 - 91' Slave Cylinder
-Mofugas short throw shifter
-Newer OEM Clutch
-Cross Drilled / Slotted front rotors
Exterior / Body:
-JDM RS Grill
-89 GS Bumper Lenses
-JDM Dual Bulb Clear corners (wired into turn signals and running lights)
-PIAA Xtreme White Plus 9006's
-TC Sportline OEM Carbon Fiber Hood
-Sunroof Visor
-Stock wheels are painted gray (has BF Goodrich traction T/A's)
Interior:
-Fiberglass dual Pillar Gauge Pod (made by Paulo)
-Defi D-Gauge series Boost Gauge
-Autometer A/F Gauge
-Alpine CDE-9870 deck ft. KCE-422i iPod adapter w/ Boston Acoustics all the way around
-MOMO Race 350mm steering wheel, hub adapter, and Niken Pedals
-Arkon PDA Holder
-VR6 Eater leather Shift Boot
-MOMO short Anatomic shift knob
VIN# JA3CX56U5NZ009049
Has 172k on the body
Known Issues:
Clear coat on roof has started to peal within the last year which is common on these cars.
Also has clear coat chips on drivers side doors (see pics). Has a couple dings and scratches
Passenger side ball joint might need replacing.
Has a problem downshifting from 5th to 4th. It started after the shifter cable bracket bolts backed off. Might just need to be adjusted or could be synchro related
No A/C, JDM compressor fittings that were on the new engine for the A/C are different so the belt and bolts have disconnected.
E-Brake cable could probably use replacing
Just started to drip a little bit of coolant
Blew out a RWS line last week on the way to the store.
Price is $3995
If you want to contact me my cell phone number is 774-200-1005 or e-mail me at cbesso@comcast.net
![dsc0035hrr.jpg](/proxy.php?image=http%3A%2F%2Fimg412.imageshack.us%2Fimg412%2F8173%2Fdsc0035hrr.jpg&hash=4f5a4be35c3652702d01175335909e2b)
![dsc0034fqo.jpg](/proxy.php?image=http%3A%2F%2Fimg21.imageshack.us%2Fimg21%2F6258%2Fdsc0034fqo.jpg&hash=f9621ca8ce8b622563e2f4c4fabe1537)
![dsc0046p.jpg](/proxy.php?image=http%3A%2F%2Fimg22.imageshack.us%2Fimg22%2F2758%2Fdsc0046p.jpg&hash=0ea56f86b74cb98a38c6a1999fd2139d)
![img2997c.jpg](/proxy.php?image=http%3A%2F%2Fimg17.imageshack.us%2Fimg17%2F7964%2Fimg2997c.jpg&hash=5580462b5851987e5e13047378abc91b)
![img3229.jpg](/proxy.php?image=http%3A%2F%2Fimg2.imageshack.us%2Fimg2%2F3097%2Fimg3229.jpg&hash=23ba1f8034ba062ad6c3fefb11bdae33)
Modifications
Engine:
-Newer OEM Clutch
Exterior / Body:
-JDM RS Grill
-Sunroof Visor
Interior:
-Arkon PDA Holder
Known Issues:
Price is $3995
