GerrywithaG
- Jul 22, 2010
NOS (in GM box) Chrome headlight bezels, LH & RH: 350
Interior Door Handles LH & RH, nice condition: 40
Stock Cassette / Radio: 90
Gabriel Pro-Ryder Shocks USED: 30
A/C Delete Bracket / Pulley USED: 35
86-87 ECU, no chip: 125
Connecting Lower Front Frame Brace #6756 Kirban, almost new: 45
Stock turbo shield: 40
Crank IC Fan: 40
IC Shroud (very good condition, no cracks) x2: 100
Front air dam (very good, no cracks): 50
Rubber / Steel GM Original Fuel Lines at motor: 100
Stroud Safety Window Net, standard angle: 20
6x 72lb Injectors (flow-tested at 70lbs) Siemens, used: 280
5x (FIVE) 60lb Injectors (5 flow-tested at 60, 1 low/bad) Delphi, used: 200
Griffin Radiator, no coolers; 300
ATR 3" SS downpipe; 200
Iron Ported o-ring heads, Harland Sharp rockers (Fresh headwork done... valves, seals, beehive springs, locks, retainers, cut valve guides. Heads use Felpro Loc-Wire #1007 gaskets (not included).; 1,200 heads and rockers.
Champion GN1 "R" full ported heads. Zero miles after fresh work done by Champion; competition valve job, seals, shims, pressure tested, cleaned. Couple track passes at most. Never saw over 14 psi.; 2,100
Crank IC Fan: 40
