Underboost
Mr. Dull
- Oct 4, 2005
Hey guys I have a Question.
I have 72lb injectors and Red Armstrong's XP Plus Double Pumper in the tank but I have been only running one pump with stock fuel rails, and lines.
I have a TurboTweak chip and do all my turning off the scanmaster & EGT's
I run a 70GTQ 85. housing @ 28psi and the Static Fuel Pressure is at 46psi w/ O2's at 780. My question is I'm putting Alum. Heads on the car. To stay with an injector duty cycle of 80% I will need to run 83's and a Static Fuel Pressure of 43psi.
Will my stock fuel lines, and rail handle the fuel delivery?
Will the motor be overwhelmed with fuel when the second pump kicks on at 10psi ?
Will my ECM with bigger drivers having a hard time correcting?
Could I hook both internal pumps up together with a new hob switch?
At what point do I need an external pump, and bigger fuel lines?
Thank you for your help on this.
I know I need an XFI.
What would you do in this situation????????
