Fuel line O-rings
DGC
Senior Member
Looking for a source for fuel and tarnsmission cooling line O-rings. GM
lists part#s 22514722 and 22516256 as O-ring seals for 3/8 inch
Saginaw fittings. These look pretty small in thickness. Alternative GM
part# 3093509 is thicker. Does anyone know which is correct? And
are there aftermarket sources?
Same question applies for the transmission cooling lines.
Thanks for any help,
DGC
If you needed them tomorrow, I would try my local speed shop and bring the old ones with me.
If you don't have time to look around for a speed shop near you, give Classic Tube a call (800-882-3711 ). They make perfect CNC pre-bent tubing for our cars. The lines they sell come with new o-rings.
Classic Tube - PreBent and Custom Stainless and OE Brake Lines and more...
You could try your local GM dealer and if available are in a 10 pack. So if you need a couple of this one and that one, I'd try either of the the above two.
Brian at GBody parts has the fuel line ones I believe. He did last year or 18 months ago.
