SignUp Now!Low Voltage and Low fuel pressure are directly related.I notices as the voltage drops on my Scan master I get a drop in Fuel pressure, are they tied in together or should be looking for something else?
and the voltage goes from 13.7 to about 12.5 volts
When we look at the numbers on the Powerlogger they are coming from the Scanmaster which always reads lower than the actual volts that the generator is putting out. However,if the numbers you see are falling,your generator is falling. If this fall in voltage is making your fuel pressure drop,your pump is at the edge of its capabilities. I always recommend Red Armstrong's volt booster. If your new generator maintains good voltage,it should make a difference. You should still have a volt booster for as much cushion as possible. The volt booster also supplies more voltage to the ignition and that it good. Do you have your pump hot wired? If you don't,your pump is seeing much less voltage than the generator is putting out. Use only AC Delco fuel filter.Just got a new Powermaster 200amp alternator, Thanks for the help.
Fuel pressure drops but not all the time, When I do notice the drop I also notice the Voltage on scanmaster drop.
I ordered a new Powermaster 200 amp adjustable voltage Alternator to hopefully rectify the problem.
Now my CK $2400. all billet transimission is slipping go figure!
The only thing I havent changed is the alternator.
Do I need bigger fuel Lines?
