I have 2 cars with no fuel pressure. car #1 is my we4 car #2 is my 86 t type.
let start with my we4 back at thanksgiving i was driving the car and i got on it and it died and i towed the car home and it sat for a few weeks and i was sick and the weather got cold. when i got better i discovered i had no fuel pressure so i checked the fuse which APPEARED to be ok. i changed the relay on the passenger side fender,checked the fuse in the hotwire kit and it was ok, well tonight i changed the ecm and still no pressure.i checked the fuses again tonight and the fp fuse in the fusebox was blown and i changed it again with another 20 amp fuse and it blew again i changed it again with a 30 amp and blew a 3rd time. the fuel pump was new from full throttle in august/september? and i had these problems 2 months later? any ideas?
car #2 with 86 t type i parked about a year ago with some issues and when the last time it ran it just unexpectedly died and i never touched the car for quite a few months and i the mean time i put a good tranny and exhaust in the car along with some other stuff and when i went to start it no fuel pressure. i tried the relay on the fenderwell,swapped the ecm. i checked the fuses and even had my buddy probe the fuse box to confirm that ther was no issue there,i thought maybe the fuel pump was no good so i swapped the whole tank,sending unit and pump from a known good car and still no luck! i get power to the relay but nothing from the relay to the tank? this car has no hotwire in it, how do i fix this car?
i am not good with the wiring stuff but i really would like to get my cars running again please help
