Have any of you ever experienced an issue with maintaining fuel pressure at start up that only shows itself when the tank is close to empty. You turn the car on and the fuel system pressurizes, I know many of us have expressed issues with the injectors leaking or the fuel pump allowing pressure to bleed off.
I believe my issue is with the fuel pump bleeding off but it only seems to be a problem when the tank is approaching empty. Have any of you ever seen or experienced this with your own buicks?
