SignUp Now!You still haven't proven that your fuel supply is inadequate. 93 octane is 93 octane. Which is heavier,a lb of feathers or a lb of bricks. The number 93 tells you how resistant the fuel is to autoignition. It has the same resistance as it did years ago. How do I know? Because of the number 93.
Do you think Joel should be able to run 15 lbs of boost with today's 93 octane on the stock chip..I disagree somewhat. The rating is the average of manufacturer rating and testing. Plenty of details about this out there, but 93 even 10 years ago was formulated very differently than 93 today so 25 years ago was WAY different, no mtbe now, more ethanol content now, etc. There is still plenty of need for a modern chip, even without the timing tables, in that Bob and Eric can make these cars run better, without unnecessary ecm functions that the manufacturers are required to put in, while still achieving good fuel economy, better than stock idle, and overall better driveability from 25 years of electronic sfi management programming skills and tricks. Heck, a translator pro and stock ecm would blow the minds of the factory engineers back in the 80s.
Are you saying that your friend was unable to run 17 lbs with a modern chip (low timing)?I think stock chips work well with a little alky. I have a buddy that finally put alky on his mostly stock car just as a safety measure against todays gas, and it's been working great for him and it barely uses any with the stockish tune. He does run a TT chip but stock pump and no hotwire!
Joel has 93 available.I can't run 12psi of boost (stock TR boost) without knock with my stock chip on 91 octane and that was a few years back when gas had less ethanol.
When and how long did you run the stock chip? How much boost were you able to run with it?
I'm guessing that since you mentioned 91 octane,you don't have 93 where you live. I'll also assume your friend doesn't have access to it. My original comment was that Joel should be able to run 17 lbs of boost with 93 octane. In 1989 my car was stock with an adjustable wastegate. The first thing I did was adjust it for 17 lbs of boost because I knew that the increased power,for a stock GN,provided by the aftermarket chips of the time came from the extra boost they created. This is still true today. It ran strong with no knock. It wasn't long before I purchased a Kenne-Bell chip which had the same fuel and spark map as the stocker. I've seen people post many times in this community that you want to stay away from the Kenne-Bell chips because they have too much timing. The extra performance,provided by the chip came from the 17lbs of boost it was burned to produce. My car didn't produce any more power with the new chip as I was already running 17 lbs. It ran strong at 17 psi with no spark retard. I ran this setup until 99. Since then,Ive always been able to and am still able,with my current set up,to run 17 psi with 93 octane and 18 degrees of spark advance. In my world the gasoline quality hasn't changed and time and time again I've seen people post these same capabilities in the turbo Buick community using 93 octane. Joel is going to be the next one to do this.Even at 12psi, he needed a splash of race gas to make it knock free with the stock chip which he ran for at least 2 years when he got the GN 7 years ago. And this is a bone stock, low mile car. He also was not able to run 17psi, even with TT chip, without knock. We probably could have drastically dropped timing to run 17psi since the TT chip is adjustable. He likes 17psi since that's what his TTA made roughly and he liked the way that motor felt @ 17psi so he always shot for that. He's a timing junky too though so he decided on alky instead of just lowering the timing to where he could run 17psi.
installing hotwire tonight, I should have new numbers later this evening or tomorrow am.
I'm learning a ton through the process and continue to be thankful to your guys approach of forcing me to understand, I'll never get it right otherwise. Your instwillingness for me to benefit from your trial and error is really something.
Thank you,
Joel
