Fuel pump relay pin numbering ????
PaulRV6
I just got this from rockauto and before I put this in I want to be sure it's correct. I realize the numbers don't seem conventional but if what I looked up is correct something doesn't add up. 1 & 2 are essentially 85 & 86 and 3 & 5 are 30 and 87. Don't relays work by putting the switched power (low current) 85 & 86 and then it controls output on 30 and 87. But looking at diagram on relay it shows it differently, I think. Please help to explain.
84-87 same relay
the fuel uses 12v commanded from ecm and ground for the relay is attached at back of the passenger head
You are right about the low current being connected to the 85 & 86 terminals controlling the high current 30 & 87 terminals on universal relays.
I suspect the vehicle specific relays could be labeled any way the manufacturer wants.
There are guys on here with schematics and intimate knowledge of the relays for these cars that I’m sure will provide more input.
I wish I was more help.
