Fuel Pump - System for Stage II
eop002
Looking to upgrade my staged double pumper fuel pump setup running the stock feed and return fuel lines on my Stage II TTA. Any recommendations on a better set up for a mostly street driven car ?
Was looking to go Weldon 2025 with their controller kit and upgrading to -10an feed line. My concern is the need for adding a sump to the tank and hassle with the baffling that came with the TTA fuek tank.
Thoughts ?
You could fabricate a larger pickup tube (like 1/2" )to replace the intank pump. Plumb that to a Weldon pump. That should supply enough fuel to support 900-1000 HP. I'd run a -10 line from the pump to the regulator, never need to upgrade that line ever again!
Weldon pumps are noisey for a street driven car. But I like that noise!!
I would look at Aeromotive Eliminator pump with an Electronic Speed Controller. Definitely go with -10 supply and -8 return. You will need to install sump in the tank or you could install the Aeromotive pump in the tank! I would also install Aeromotive 40 micron SS pre-pump filter and 100 micron SS post-pump filter. This would all be compatible with E85. Aeromotive has just come out with a filter/shut-off valve with dry-break to prevent spilled fuel when changing/cleaning filter element. Take a look at it as well.
Conrad
E85 Tech Administrator
Here is my setup. I had Ricks Hot Rods build me one of their stainless tanks with a custom -10 pickup but you could easily modify the stock sending unit in the same manner.
-10 stock style pickup to externally mounted Weldon 2015 mounted above tank in location where stock muffler originally resided. Yes - this pump can lift the fuel just fine and is perfectly streetable. 40 micron pre-filter and 10 micron post filter. -08 line to the rails with a -06 return line. I run an Aeromotive pump controller to keep the noise down on the street and to help keep the fuel cool.
