If I power pump directly at the rear harness , it comes on. If i power up the grey prime wire behind alternator, nothing. I am getting power to the relay, I ordered a new relay becuase mines original, but it wont be here til tomorrow. The orange wire to the battery is hooked up, the fuses are all good. there is no aftermarket hot wire kit on it yet. the car came back from the body shop where they totally disassembled everytihing on the doghouse, removed, doors, etc , car was completely painted, but it had this problem the day i towed it to the body shop. It starts off staring fluid so I know spark is there. I dont see a ground strap on the tank, so I will add one . Any ideas of what else to check.? Maybe a missing ground by the ecm,??? thanks
