I haven't weighed car but should be ~3600-3700 stock, I'm doing quite a bit of chrome moly chassis upgrades, k-member, front and rear control arms, coilover suspension, torque bar, etc. which all should lower the weight a little but also getting a 10-point chrome moly cage and subframe connectors so I'll probably gain back what I lost with the front end parts? I may go fiberglass hood so that will shed a few lbs as well. Motor is a fully built 0.040 over 109 with a 219/219 Comp roller, billet mains, Eagle crank, K1 rods, Ross pistons, internal balanced, TA cover Champion ported heads and intake, etc. Should be around 9:1 compression. I'll be running 28" tires currently have 295/55-15 MT's but may switch to 275/60-15's still 28", currently have 3.70 gears but will probably change that to 3.50's eventually when I swap in the Currie 9" later this year, probably next winter.
