SignUp Now!I know a lot of people run dbl's and probably most never have any problems but that one time one pump fails I'm not even sure if the XFI can save you. The only head gasket I have ever blown was do to a failed pump (the Walbro rejects that came out several years ago) at wot and 25 psi with alky set on 6 just before the traps. Now I have a crap load of more money in this new build and the possibility of one pump failing really concerns me.If Your second one doesn't turn on for whatever reason you better cross your fingers it doesn't hurt the motor
wat happns wen the single fails?If Your second one doesn't turn on for whatever reason you better cross your fingers it doesn't hurt the motor
well if its at idle its not gonna hurt ur motor and if ur under WOT it will happen so fast ur not gonna know till its too late unless u have an XFI with fail safe features.Depends when it fails. Could be at idle could be at wot. Could fail slowly could fail instant. I log fuel pressure so it might or might not show in the data logs.
What I'm trying to get at is I would rather have a single then hope my second pump turns on. More often then not, your second pump will be triggered at wot. As much as we put into these motors it's safer imop to run a single. Yes with good wiring a double pumper shouldn't fail and probably won't.
No mater which way you go you will be happy. If a single 400 pump will work go that route. If not you got other options as well as the double pumper route.
What about the Racetronix 430lph? Should be plenty of head room there.
Thoughts on the Aeromotive A1000 external pump?
