BBcallaway
- Jun 21, 2007
Looking for steps on how to remove a gas tank from a 87GN. Fuel is still in tank.
SignUp Now!Looking for steps on how to remove a gas tank from a 87GN. Fuel is still in tank.
Thanks,but since the fuel is about 8years old we dont want to build any pressure. Any other way to drain it with out using power?
Bruce
Is this to remove the tank or the fuel? I'm getting confuzzzled![]()
8 years old huh. Sounds like you need injectors removed and cleaned or replaced. You need a new fuel filter, pump and the rubber lines just after the tank should be replaced. Using the pump rail drain method is a good idea if your not experienced enough to drop a G-body fuel tank which is a rather simple job. If you keep the fuel in the tank and things get out of hand on the way down you're going to hurt yourself, damage parts, and really regret not draining it.
Bruce
Thanks guys. We discovered the pump is kaput, so we could not pump the old fuel out. Tank came out easy as there wasn't much gas
left in tank.
Thanks again guys.
No 418 is fine. A buddy of mine bought an 1987 Gn new but it has been parked for 8years. 26000kms on it. Needs tires exhaust , fuel pump for starters.
