GNBRETT
Pelennor Fields
- Feb 8, 2004
Ok, so the jackass propane guy delivered propane to my house this morning and for some unknown reason he thought no one was home and turned the valve on the propane tank off!
The barking dogs, car in the driveway, lights on in the house I guess was not a BIG enough clue to this moron to think to actually knock on the customers door before he turns the valve off which turns the pilot off.
My pilot is not very easy to get to as it is in the attick. I have no basement.
Anyway, I did not realize that he shut the pilot off till cool air came from the vents after this jackass left....
Anyway, so I climb up there (Not easy since I just had shoulder surgery last week and am in a sling) to turn the switch to PILOT. I wait two minutes while depressing the pilot buttom which is supposed to open up some filiment to allow PROPANE to flo thru the main valve.
Well, I did that and it worked fine. Switched the switch back to ON and the flame was burning fine.
I went back downstairs to turn the blower motor back on from the thermostat control panel. It starts blowing air but it's still cold. So I go back up stairs to see that the flame is no longer burning.
I attempt the re-light the pilot again but when I switch it back to PILOT and depress the POLOT button it wont stay on after I remove my finger from the PILOT button to switch it back to the ON position.
I had the PILOT button depressed for about 3-4 mintes this time and when I remove my finger from the button the flame goes out so therefore I cannot switch it to ON so the burners can burn??????????
Anyone have any suggestions? It's fuken COLD in here!!!!
It's down to 56 degrees and expecting a low of 12 tonight!
Pipes are gonna freeze. Tried calling these azzholes back to send a tech out but no one calls me back. I have tried like 7-8 times.
Anyone? Thanx....
Anyone? Thanx....
