Pronto
No amount of evidence will ever persuade an idiot.
 - Dec 9, 2002
Ceramic balls are also used for mixing things like paint in cans and ball mills where they grind items smooth. Think pmoore4321 has it right.
SignUp Now!I had bad luck with those Earls fittings when I tried installing my fuel pressure gauge. First one lasted a year, second one lasted a day or two. Turbofabricator referred me to a website that sells stainless steel fittings. Hasn't failed in 3-4 years now. I think maybe those Earls fittings are made for low pressure carbureated cars.I couldnt get the -6 an (earls brand) return line to seal right near the tank. I first tried a cheapo china made piece (-6 with a 3/8 hose barb) in the fitting and tightened down. It leaked all over. Then I tried a russell fitting. Didnt work, still leaked all over.
True! Very important to not mix and match hose and fittings from different manufacturers on the same assembly.JIC fittings are the same as AN. Lots of places online sell the JIC ss fittings. Some hose manufacturers use hose that need their specific fittings though.
Sounds like your issue with the line might not be the fitting its self. Are you sure you cut the hose good and square and have it pushed in all the way? The woven metal shielding can mess you up too. If it's not assembled right it will leak. The leak can look like it's coming out fitting. I would take the time to remove the fitting and double check how it was assembled.
Vacuum sources become pressure sources unless there is a one way check valve in them.
Boost gauge installation. http://www.gnttype.org/techarea/bodygauges/bgauge2.html
I stated earlier that my boost gauge wasnt working. I think I know why. It is a boost only gauge and should be connected to a pressure source not a vacuum source.
