blipmode188
- Jun 28, 2007
Can someone follow this link and tell me what the yellow connector is on top of the gas tank ? I have my tank lowered (not all the way out just dropped a little) and can see the connector. (3rd and 4th picture)
How to install an intank fuel pump. - TurboBuicks.com
The pump shuts down sporadicly, incidentally the fuel gauge also stopped working about the same time the pump problem started.
When the pump shuts off, if i slightly pull on the wires to that connector the pump kicks on ?
Is that a connector or some sort of weather cover ?
I have looked everywhere to try to find one but cant seem to find anybody that has one.
You can find hot wire kits all day long to plug into the factory wiring, but if the factory wiring is bad what do you do ?
Thanks again for any help or advice.
Steve
Steve
