Apr 4, 2009 #1 J jerrad Member Joined Aug 21, 2004 Messages 534 I'm going to be installing a cam in my near future and was wondering where everyone is getting the gasket sets and what brand will do the trick. I'm assuming I'll need the intake gaskets and the front cover. Am I missing any? Thanks
Apr 5, 2009 #2 B Blown&Injected Active Member Joined May 31, 2001 Messages 3,721 valve cover gaskets - all in stock at most of the big chain parts stores.
Apr 5, 2009 #3 J jerrad Member Joined Aug 21, 2004 Messages 534 Thank ya sir. Should I get any gasket maker to hold the gaskets on?
Apr 7, 2009 #4 B Blown&Injected Active Member Joined May 31, 2001 Messages 3,721 I do not use it but some on the VC side might make it easier to install
Apr 7, 2009 #5 N novaderrik Well-Known Member Joined May 12, 2004 Messages 8,076 it would probably be cheaper to just buy a complete engine gasket set- the only gaskets you won't need are the head and oil pan gaskets.
