gauge wiring
85ha
I am installing VDO gauges on my hot air. On the oem oil sending unit there are 3 wires, I know one has to operate the light in dash but what are the other 2 wires for? Is there anything that needs to be connected to these wires after I wire in the new sending unit? I read somewhere that these are tied in to the starter circuit but Im having trouble finding info
Two of the wires power the fuel pump relay with normal oil pressure.
You can locate his info through the sticky. :cool: Here is a schematic.
http://www.installationinstructions.com/vin9/injectors-fuel system.pdf
