278cikiller
- Dec 21, 2007
Gauging intrese in selling my Stage II motor.Off center. This motor was never hurt with no sleves,it has a internail oil system this is not a dry sump motor.
153 block
4.030
BMS 3625 crank
deck HT.9.484
Rod Eye Width 1.108
rod length 6.20
Wrist Pin Dia .927
Comp ratio 8.5:1
JE pistons custom
Motor comes with GN-1 heads unported,untouch.
TD 1.65 roller rockers
stock intake ported to felpro 1200 gaskets raised runners
70mm throttle body
7 litter oil pan
206/212 roller cam brand new Roller lifters
smith and brothers one piece push rods 3/8x5/16x 8 3/8" long.
Looking to see what price this is going for these days any input would be so kind thanks.
This motor is still in car.Motor does not come with headers.down pipe,turbo,and injectors or cam sensor this is a drop in motor add your turbo,injectors,headers and down pipe and cam senser you have a rocket of a motor
153 block
4.030
BMS 3625 crank
deck HT.9.484
Rod Eye Width 1.108
rod length 6.20
Wrist Pin Dia .927
Comp ratio 8.5:1
JE pistons custom
70mm throttle body
7 litter oil pan
