just plain john
El Camino a Go-Go!
- Feb 24, 2007
I swapped the GN rear today into my El Camino today, and ran into an issue I hadn't thought of. I have Weld Draglites on the car. When I went to mount the wheels, I found that the wheel studs are 1/2 inch, not 7/16 like the stockers. I also have Belltech drop spindles on the front, and they spec the same part number for G bodies as well as earlier S10 trucks. Do Regal rotors have 1/2 inch studs? I was going to do the complete brake system, and the back brakes are done (S10 manual brake wheel cylinders). Now the fronts. Is the Regal rotor an easy swap? I don't know what bearing sizes are involved, but I do know my 81 model has different larger bearings than the 78 and 79 El Camino. Turbofish38, are you listening?
