Gen 2 airflow readings with an ls1 maf
evil666
Hi guys
I would like to know what are your air flow readings with a gen2 and ls1 maf with an extender extreme chip. My scanner reads 246 at full throtle and would like to know if that is normal.
Thanks,
Marco
T-Top 86 Grand Nationals (63000km) 109 block with weisco forged pistons and 2 billet center main caps, M&A aluminum heads, roller rockers, port match lower intake ,te63 a.r .82, erson 214/214 cam, razor alky injection, 94 octane, hooker cat back with dyno max ultra flow muffers, kenne bell headers, 60 lbs injectors, extender alky chip with 21/19 timing, with a gen 2 with a LS1 maf,thdp, mease 24 row IC, PTC 3200 stall 9 1/2 convertor, Ron Custom max boost brake module, MT drag radials (275/60/15) , rjc power plate, rjc boost controller, zeitronix wideband, HR motor mounts, Weld Drag Lites with skinnies up front, electric exhaust, hr rear sway bar, no front sway bar, 90/10 lakewood in the front and 50/50 lakewood shocks in the rear with energy suspension poly bushings all over, boxed rear lower control arms, Big mouth cold air with an AFE air filter
BEST E/T
60FT=1.48 (foot brake on 4 lbs of boost)
1/8= 6.65 at 100 mph
1/4= 10.83
MPH=105.2 (letting off the gas, car was running to lean, double pumper for next year)
Triple Air FLow Numbers with Extender Extreme Chip
Hi guys
Thanks,
Marco
BEST E/T
1/4= 10.83
Sounds OK to me.....you gotta remember that you need to triple your air flow numbers on the SM when using the Extender Extreme Chip!
dave
Hi guys
Thanks,
Marco
BEST E/T
1/4= 10.83
What did you read those numbers on? The Scanmaster or GenII?
Man I've got to get mine tuned. 6.65 in the 1/8th. I am jealous. I might have to call you for some tuning advice. How much boost?
I read those numbers on a OTC 4000e scan tool.
WOW ,when you work out the bugs this could be a 9 second contender.
Hi Bob
I wish but I don't think so, maybe 10.30 to 10.50 with the fuel issue solved, depending on the 60 ft. I still have the stock TB and plenum, but if I would upgrade those parts and with a 67 mm turbo I think I would get really close. If I would switch to real slicks instead of drag radials so I could launch the car at atleast 10 lbs of boost, I wouldn't be surprised to hit a 9 then but my stock rearend wouldn't last that long.
I am running 22 to 23 lbs in first, 23+ in second, and 23 to 25+ in third.
Thanks,
Marco
BEST E/T
1/4= 10.83
So, your actual MAF flow is 738. Seems high to me, based on your boost, etc.
