Gen 7 help
Blowen LT1
Kinda a weird questions
There are a few things that I have had all year
code 23 tps voltage it is there every time I start the car ? I have talked to another guy with an LT1 and Gen 7 and has had the same thing?
Is there anything that might pop into your head on what to look into?
2nd...
the car all year has had a miss???? but the miss is intermittent...
you drive the car and it feels like for that one sec something is Turing off it is a real dead spot, it will do it under light load under 3000rpm or if you are trying to pass someone on the highway under 1/2 throthal, I don't think it is doing it at WOT...it didn't show anything on the dyno......
what should the WB02 line look like when driving around town......mine is spikeing up then down..not very smooth at all....should it be straight and what should I set the read time at..
thanks
I have Gen7 with LT1 TB on my buick and I have no problems or codes. I would just check the sensor/wiring. The LT1's have fixed TPS' so the only thing that would change it is the throttle plate position.
Phil
The WB shouldn't really jump all over the place, although there are many parameters that would affect it, esp. at idle exh velocities.
Phil
