gen vii with 2002 software......this system use to be on a mod motor....now it is on a 351 ford with 72lb inj i have no spark at all i have replaced the coil, and module...i have 12v while cranking at the coil and computer....the dashboard on the dfi shows over 100rpm while trying to crank. the config is crank signal 5v and output is unipolar
i have taken the coil wire and tested it to a ground and the coil fires. Is there something that i have missed? why is the signal not coming out of the accel?
