I've been having some problems with my car running hot. I mentioned them to a friend and fellow board member Carl Ijames who recommended sealing up the gap between the fan and the radiator, and the gaps between the radiator and the the body. I picked up some "air conditioning weatherstripping" from the local hardware store and did just that.
The weatherstripping isn't the sticky back stuff, it's actually an open cell foam with a square cross section. I used two different sizes, 1 1/4" X 1 1/4" to seal the gap between the fan and the radiator and 2 1/4" X 2 1/4" to seal the much larger gaps between the radiators itself and the body.
The difference has been quite dramatic over the last week or so. My average temps appear to have droppped roughly 14 degrees or so (monitored via direct scan) at cruising speeds and the cooling system doesn't become heat soaked as easily from playing around when it's hot out.
Next step will be the Ramchargers dual fan unit then replacing the stock radiator in preparation for a front mount
Thanks for the tip Carl!
Charles Brooks
Charles Brooks
