Getting Rid of Flowmasters What to Get?
kwcook
Getting erid of the flowmaster exhaust and am looking for the best set up performance and sound wise. The car is basically street but I am back to working on it and wnat it to run stronger.
Hooker Super Competition Cat-Back Exhaust Systems? Is this ok and will it work for an 85 T Type?
The Hooker setup was a nice, inexpensive upgrade from the stock $299 and $80 install. Not too loud either. If you are looking for the most performance, 3in single shot is the way to go. I went with the Hooker because of stock appearance and they include a 2.5 in test pipe. 3 in test pipe with dump would be a better choice.
The system is stock appearing but isnt there still is some fabricating to be done as far as welding hangers. I am looking for a good sounding exhaust system that has very limited popping. I want performance but odds are the car will rarely see the track if ever. I have 2000 ws6 with borla catback system and it sounds awesome.
where did you get the Hooker exhaust for 299? I looked at summit and the kit is 339
KWCOOK- Based on your needs go with the Hooker Hi Flow system. I got mine from Postons-Now $359 plus shiiping. It is a 2 1/2 inch setup There is a slight modification to the downpipe converting it to a four bolt flange versus a 3 bolt stock 85. Any exhaust guy can handle it. I am very happy with mine after 2 1/2 years. Brad
Brad
I have read a lot of posts with your feedback and I am curious about your set up. If I got all the kinks worked out of my T Type I would definently consider Razors Alky System. What should your car run properly tuned with good traction. I would like to do most of your mods except the heads and boreing of the motor currently.
Thanks For the Input Everyone
If anyone needs a stock hot air downpipe with a 4 bolt flange on it for the aftermarket exhaust let me know, I have one. -Nick.
