I have not posted about oil pick ups as I’m still studying what’s available. The Mellings 20is, and sealed power that I can’t remember exact part number right now ( 224-128 maybe).
Anyhow I have found some with the fine screen, but under the support bar some have an open hole as a bypass for a plugged screen, I’m sure oil will take the path of least resistance. I lost a motor due to this in 2014.
I have found some fine screen pick ups that have a solid screen with no bypass hole.
Others have a coarse screen that is solid, no trap door or open holes hidden under a bar.
So I’m curious if anybody actually looked/looks under that wide support bar and sees a open hole in the center, or if it’s solid like some I have seen. Please provide your findings and what part number you have.
