gmpartsdirect vs. AC/Delco
mark b
Do I have this right? GM Parts Direct does not list AC/Delco parts? I have an electrical part that shows on ac delco but is not found on gmparts.
Anyone order A/C Delco parts via the web at discount?
Plan B is to go back to Dal Slabaugh even though this isn't a TR part.....or the boneyard
TIA
There parts search engine only accepts GM#'s not AC Delco #'s.
Try and go to ACDelco.com and convert the Delco part number back to a GM #.
A/C Delco parts
Give me the part number and a description of what it is and I can get it for you myself (GM Parts guy). :)
P/N
I tried to cross that number you have but it's a no go. It must be an outdated number. (it happens quite often). On the other hand I did look the GM part number for you. It's 12065122 I did try to cross the GM number to an A/C Delco and there was no referance for it. I hope this helps alittle. :)
