SignUp Now!I ordered one up!You will likely want to get a 2-circuit weatherpack connector to make the solenoid plug into the stock boost solenoid connector.
I have the solenoid with the connector pre-installed on my site
https://www.bailey-eng.com/product/hi-boost-solenoid/
Bob
Bob
Bob,You will likely want to get a 2-circuit weatherpack connector to make the solenoid plug into the stock boost solenoid connector.
Bob
Bob
SpeedRacerX said:Bob,
I'll be running the ecu-gn soon, wideband O2, etc. For now, I'll still have my downpipe with internal wastegate. I also have the factory boost solenoid and Hallman manual boost controller but I'm not married to them.
Please let me know what I need to buy or change out so that the ecu-gn can offer boost control/protection?
I'll keep my scanmaster-g (if you recall you fixed the dim screen issue for me) but wondering if a critical gauge I should have in the car is an air-fuel ratio gauge??
Thank you,
Randy
Thank you.SpeedRacerX said:Bob,
Thank you,
Randy
PM's won't let me reply. I see the messages, but never got the notification.
The ecuGN can control the factory solenoid, the control range will be the same as with the stock ECM. Its easy to set up, and if you need some help, let me know.
Boost protection, and leanout protection is easy to set up, and doesn't require extra hardware. You want to make sure you don't cut fuel if you are running alky though.
Scanmaster G will work great for you, I have a software update that adds some more stuff. I can talk you thru updating it, or you can send it here at some point.
Bob
