1986 Buick GX1
GX1 #001 [The One and Only]
- Apr 24, 2015
Remove front bumper turn signal lenses and cut off the inside portion of housing, the part with the 194 parking light lamp. Remove lamp and tape socket as it is not reused and will not affect turn signal function.
Grind/ sand the front outer edge flush with the fluted part of the lens as well as the front and backside of the mounting bosses. Fill the space in the remaining turn signal housing with black silicone so light doesn't get out or dust get in.
Make the driving/ fog light mounting bracket. I used 18 ga aluminum, 13" long, 2.5" max height (from bottom of bracket to the inside of the bend) and 1.5" deep (depends on light mounting) cut holes in the front panel for the turn signal to shine through and the driving/ fog light (shape depends on light used). I used a rectaganal light. The mounting bracket is sandwiched between the turn signal lens and the trim ring
Slide housing as high on the backside of the mounting bracket as you can, center, mark and drill holes (3/16") through the front panel to attach to the bumper. Clamp or bolt the mounting bracket to the front of the turn signal lens and mark holes in the top panel to mount the driving/ fog light (whatever size the light mount is, mine were 1/4").
Assembled on the bench
Check fit assembly.
I had to trim a bit (1/4"X 45 deg) off the bottom front corners. Disassemble and paint the mounting bracket to suit. I used black of course.
Reassemble and enjoy the view.
For those who like a more subdued look, with a tinted cover.
Left is cleaned aluminum for the chrome bumper folks and the right is painted black.
Of course there is wiring and aiming involved as well.
Check fit assembly.
