GN Seats, Baer, Governor, head studs, coolant reseviours, modded ecm, hood ornament, lots more!!!
jdpolzin
I have a bunch of parts that are getting cleared out:
87 GN Seats, almost mint,full set:$600 sold
87 T Type Center caps: $35 each
Stock Radio with 5 band Equilizer: $75
Stock Radio: $50
Modded ECM:$250
87 T Type Center Caps:$35 each
Trick Flow 120# Injectors (2 spare):$100
Wastegate solenoids (3 left):$20 each
Escutcheons:$25 each
Powermaster core:$100
Powermaster pedal:$10
Oil slingers:$5
20 bolt oil pan:$50
Turbo hood ornament:$50
Chime boxes:$8
EGR solenoids:$8
Chrome EGR cover:$8
87 GN Steering wheel core:$35
87 T grey rear carpet inserts:$20 pair
Hot air oil fill tube:$5
New GM Coolent reseviours:$35
Coolant reseviour caps:$5
Passenger under dash covers:$15
Drivers A pillar grey stock trim:$25
Dash surrounds 84+87 GN:$25
NEW oil pump repair kit:$10
6 pushrods 2 DOT, one polished:$20
New rod bearings 20 under:$10
Chrome bumperettes:$10
New Baer brakes for Ford 9":$500
3rd brake light 87 GN:$30
1/8" Valve cover spacers:$15
Chrome wiper arm set:$25
Dust/Inspection cover:$35
Seatbelt actuators:$6 each
Stock Balancer:$45
Battery hold down bracket:$10
Stock rocker arms:$5
Floor shifter:$35
IC brackets:$20 each
Used knock sensors:$5
KYB Rear Shocks (used three months): $50
Black Wiper Arm Set: $40
Drip rail (Passenger side, black)(2) $10
A pillar Trim (Black, drivers side riser) $10
Rear window trim (black, drivers side riser) $10
Chrome Key Lock set (dors, trunk) $10
Lighted Vanity Sunvisors (need covered, unsure if the lights work) $20 FOR BOTH
Chrome bumperettes:$10 front or rear
Turbo hood ornament:$50 pictures of both would be great
Big Dutton, the brake are new and still in the box. I mounted them on a new housing and ended up selling the housing so they went back in the box. The only thing I did was paint the calipers red. Here's a pic of the kit. I sealed the box back up but if youd lie me to pull them out, I'd be glad to do so for you. They are new and undamaged or used in any way. They never had brake fluid in them and also were never mounted in the car. ----Jeremy
1 Rippen, I'll get the bumperettes out tomorrow and take a pic for you of them as well as the hood ornament. I'll have to check whether I have all four or just the two fronts. I might have the rears but I'm positive I have the two fronts. -----Jeremy
For some reason the server isnt letting me post pics. If you would like pics of particular parts, shoot me a PM. ----Jeremy
Hey Jeremy , how many stock boost solenoids do you have? Ill take one if available for sure. Thanks Joel.
Interested in head studs, for 109 block right?
PM me a response with payment info,
Hey broski! I sold the one I had that was complete. I think I have one more in my stash drawer that I kept for testing purposes. I'll double check and get back with you.
Cool man. No worries if you don't wanna sell your spare either. Just figured I'd grab one. When u got some spare time would like to rattle your brain with some stupid questions again. Lol thanks bud.
Anytime. Give me a buzz tonight if you want. I'll be in the garage hanging out.
