434nova
- Sep 30, 2013
I pulled my gn1 shaft rockers off my gn1 heads and what looks like a roller bearing fell out from the rocker thru the shaft bolt hole. Is this normal or is there a problem ? I can take the c clip off and check the rockers but why would they make a setup where if the rocker goes over the bolt hole one of the roller bearings can fall off ? Actually I have 3 that fell off. I knew I should have left the 3 shaft bolts in. Also does anyone know who makes the gn1 shaft rockers ? This valve spring swap is becoming a headache now. Thanks for the help in advance.
