Just wanted to verify with a few of you what your torqing your GN1' heads too. Im using previously used heads studs and bolts on ALUMINUM GN1 heads. Champion spec reads 75ft lbs. Most seem to think its not enough. I cant remember what i torqued them too last time. But i did 90 and stripped the bottom of the thread in the block on one Also seems people are torquing the longer studs higher than the shorter ones. Yes, I did do a search and found varying info, so just thought Id reverify. Also what are you torqing the intake bolts too for GN1's and rocker shafts. (Might as well get all those questions out the way) I do have the torque sheet printed off of the other website but wasnt sure if that applied to aluminum heads
