hemi8
Goin Sideways
- Jun 6, 2001
I am in the process of gathering tools to remove a valve spring on my GN1 heads (in the car, heads on) and have run into a snag. The holes for the spark plugs is so narrow the fitting for my leakdown tester will not screw into the spark plug hole. What fitting have you used to connect to your compressor to hold the valve up while changing the spring?
Mike
86 GN
Mike
86 GN
