BuickMike231
60% of the time, it works every time.
- Feb 21, 2007
Hey guys I just recently installed a line lock kit from GNS Performance and did a little walkthrough with pictures so you can guys see what the kit looks like installed. Enjoy!
GNS Line Lock Kit Installation
I just finished up installing one of the line lock kits from GNS Performance and wanted to share my experience with the install of the kit. First off, Scot W. is a pleasure to work with and answers any and all questions in short order and ensures you have all the info needed to install any of his products. Second, the kit itself is fantastic! It showed up packed very neatly in separate bags with the carbon fiber bracket (which is extremely well done) packed in bubble wrap.
Here are the contents of the kit: the carbon fiber bracket, the rubber hose to go from the solenoid to the master cylinder, the line lock solenoid, the brass fittings and screws for the solenoid, and the switch and fuse along with the instructions for wiring and installation.
Here is a close up of the bracket; it is a very well built and great looking piece.
Here is a close up of the other components.
Here is the rubber hose which eliminates bending more hard lines.
Here is the line lock solenoid mounted to the bracket.
The instructions for mounting the solenoid are very clear and easy to follow and the wiring instructions are equally clear and straightforward. Scot has the bracket installation laid out in a step by step fashion with the brass fittings numbered so you literally just have to follow along with the instructions and you will have your new line lock installed in a very short amount of time!
Above is a picture of the side of the power steering reservoir showing the two 10mm bolts you will need to loosen to slide the bracket in place. You will also need to remove the rubber cap (if yours is still there), nut, and clip that retains the cruise control cable from the stud shown just above the power steering reservoir in this picture.
Here is the stud with the nut and rubber cap removed; the clip is still there at the moment.
Here is the cruise control clip that needs to be removed, this is not used afterwards as the cruise control cable tucks nicely underneath the bracket.
Here you can see the bracket and solenoid in place. The bracket drops right in place and slides onto the two 10mm bolts you loosened earlier from the power steering reservoir. This bracket fits like a glove! As you can see it’s contoured perfectly to sit right around the washer fluid reservoir and is NOWHERE NEAR the front hardline on the master cylinder. There was a thread on TurboBuick.com a little while ago where a guy was complaining about the fit of the GNS line lock kit’s bracket saying the front hard line was in the way. This is absolutely not the case. There was no bending or manipulating that front line at all, what you see is exactly how the line was before the install and the bracket drops in no problem.
Here’s another angle of the bracket and solenoid installed. As mentioned above, there is absolutely no interference with the front hard line at all and there is plenty of room for the bracket to sit. There is no forcing or trimming needed to get the bracket to sit where it needs to, it literally falls right into place. (Don’t mind the dirty engine compartment!!)
