SignUp Now!What's the price?The trans cooler was made by ACDelco, it was a production part for another GM vehicle. ASC made their own brackets. They are discontinued and all are gone from the GM parts supply. If you need, I have a new one available.
If jamestown sells out i have nos cooler with all three brackets and lines $495 shipped.
I got mine off A Cadillac too. Made the brackets from the two factory illustrations of the GNX trans cooler. I used the special parts supplement and the owner's manual supplement as visual guides.
If you get one from a scrapped Cadillac. Get the U shaped trans line up near the Radiator while your there. It is pre bent in a smooth shape for good flow and it has a fitting on it you'll need.
Almost to easy with the grill removed. I think I have $50. total and my time in the whole thing.
Good advice.. I have a plate-style cooler and wanted to see if I can make it look like a stock installation....
have a picture of it?
I recently noticed an aux cooler on a late model Tahoe in the same location. Pretty stout looking piece and it is a plate cooler.
[I'm wondering if the plate cooler isn't as efficient as the the aux cooler the GNX was equipped with in an air cooled application in disapating heat?]
Well as usual when I don't know something. I go looking......
First,
The plate aux. coolers are more efficient in heat transfer in water and air.
Second,
The routing of trans cooler lines. Since it seems everyone has differing ideas on how to do this. So I called a crazy Bert Rutan type inventor friend of mine. Ted has 28 pattens (so far) to his name and because of some of them. He hasn't the need to work 9-5. [ie. How do you tap into a fiberoptic without cutting it? That is one of the ones the government men in black wanted.] If you can interest Ted in something, he will investigate it down to the atom. He said he tried all cooler line configurations and compared temps before and after. He concluded the way I stated earlier is the best way to cool the trans. fluid in cars in everyday usage.
Hope this helps.
