Going LSx, Parts FS!!!
Interested in a 109 short block.Will you ship if i pay shipping?My zip code
is 92064.When you have a chance let me know.
Thanks,John
Thanks,John
I dont know if I want to get into shipping an engine across country, Im looking for more of a local pickup or meet-in-the-middle kind of deal, that way the buyer knows what their getting.
Test pipe and Kenne Bell throttle body and upper plenum sold!!! Everything else still available!!!
87 Turbo 3.8L Grand National Longblock (needs rebuilt)
"109" Block with ARP Main Studs
Stock Turbo Crank(need replaced/machined)
Stock Turbo Rods w/ ARP Bolts
.030" Speed Pro Forged Dished Pistons(8:1 Compression w/ Stock HG
1445 86-87 GN heads w/ 100lb springs
Oil pan, front cover, oil pump
$600 can seperate
3" Downpipe w/ HKS Wastegate(Custom made for Third Gen Swaps, will connect to 86-92 Single Cat Exhausts, will include catylitic converter $425
#55lb Siemens Injectors Low Impedance(6) $225
TurboTweak 93 Octane Street chip, burnt for #55lb injectors & TE44 turbo $50
GN Fuel Rail $30
Alternator (105a output) $40
Crank Sensor (Napa brand) $30
Crank Sensor (unknown brand) $25
3200 Stall Fuddle Racing Converter(made for TH400 to mate to 3.8L) $250
Kirban Spark Plug Wires(w/ gm style wire seperators) $40
Coil and ICM (Autozone stuff, good backup)$80
Factory steel vacuum tubing(could be sanded and painted)$30 or $40 w/ vacuum block
"Buick" engraved EGR Blockoff plate w/ gasket $10
AlkyControl Single nozzle Methanol Injection kit(for 89 TTA's and 82-92 Fbody's) only ran twice $380
MSD 3 Bar Map, practically new $45
GM 2 bar MAP $10(have 2 of them)
Factory Wastegate solenoid tubing(bought but never used) $15
AC Delco GNX Oxygen Sensors $25 each
Oil cap/breather $20
Passenger Side Valve Cover breathers $10 each
Vacuum Block w/ fitting for Vacuum Brakes(includes good gasket) $15
HD adjustable wastegate actuator $45
GN Factory wiring harness holder(big L shaped thing) $15
GN relays(fuel pump and coolant fan relay?) $20for both
Coil Pack Mounting bracket( U-shaped thing) $10
GN water pump(good bearing, mating surface, needs painted) $20
GN Oil dipstick and tube(writing wearing off) $20
Oil drain tube $10
-4AN Turbo Oil Feed line(Earl's fittings and hose, custom made by me) $30
Stock 3.8L Pistons(good shape, just went bigger) $30
Turbo Intercooler shroud(good shape, just missing screen) $30
All prices are obo, I have pics available upon request. Ill likely post them tomorrow!!!
Chris
Parts
send Pay Pal info.for items listed
EGR block off plate $10
Vacuum block for Vac. brakes $15
4AN turbo oil feed line $30
thanks for Your help in this matter
Ed.
how much just for the 109 block and ARP main studs? really needed the EGR block off plate!?!
Ed.
PM Sent
I dont want to freight the engine and wont part the main studs from it. Ed. Kaye is first in line for the Block off plate but Ill let you know on that.
Chris
how much for the stock pistons shipped to 23666(Hampton, va)
