good alky turn on point
mikeneedacar
what is a good turn on point for stock turbo 36# inj. 307 fuel pump hot wired, adj fuel regulator, trans ls1 maf. trasher chip.
and oh yeah its a how made alky kit with a hobbs shurflo pump and nos .30 jet
Probably12 PSI. Depends on how your car responds to alcohol. How fast the turbo spools, what boost your running, etc. Example a car with 3.73 gears, small tires, stock turbo, converter, etc.. will spool so fast that turnon needs to be at like 7 PSI. A car with a bigger turbo, stock converter, slicks, etc.. you can turn it on 14-15 and have no issue.
Watch your knock guage, it doesnt lie.
Keep that motor from knocking, it will live a long time. If you get detonation, your doing something wrong.
