turbojimmy
Supporting Member
- May 26, 2001
I was having trouble finding the source of the problem.....oh wait, here it is:
Here's the piece of head gasket I found when I first removed the intake manifold:
The other head gasket doesn't look too good either:
Bearings are toast (the screeching noise kind of gave it away):
Crankshaft is scored:
I'm pretty much looking at a total rebuild here, correct? If it were your engine, what would you do? Slap bearings and gaskets in it? I mean by the time the crank is cut, new bearings are installed, heads fixed, etc. I might as well do the whole thing? The next thing to go will be the cam anyway from the graphite in the head gasket?
Jim
Jim
