Got Razor's kit for my Birthday!
Robbie-87plz
Junior Boost-Head
Was a very happy :D man when the wifey said Happy Birthday ;) and presented me with Julio's kit. Thing is I'm scared :( to install it. It's sitting on my living room floor spread out in display fashion :cool: . I'm not sure where to mount the tanks. Can someone help me with that? Figured, that will at least get me started. Aloha.
It's not as daunting as it looks..even a relative dumbass such as myself was able to get it in pretty clean...mount the items where Julio recommends, Alky tank in place of overflow, pump on the bumper support bracket, new overflow can be inside the fender, on the fans, or behind psgr headlight...and if all else fails, Julio is an email or call away..he was VERY helpful to me
It was my first time out with a soldering iron, since that's what Julio recommened for the connections. I was pleased and If I remember correctly it took me about 4 hours.
The thing that helped me with the install was that I figured - Hey, I don't care how long it takes. I also didn't care how long it took someone else ('cause I'm kinda slow)
I made it a "no pressure on me" kinda deal.
If I can help, let me know. My install might not be the best - but everything works. :)
Paul
You guys are the best :) ! Razor got a holt of me yesterday and we talked some...I gave my fears and worries :eek: and he was like look, call me when you're ready to start :) . In my humble opinion :o , that goes along way with someone that gets parts from vendors and they're "not in the office" when you have a question :mad: . Mad props to Razor! :cool: Not if we can get him into developing other "parts"..... ;)
Robbie-87plz said:
Thanks for the reply J...how long did it take you to install it? :D
Unfortunately, I had to clean someone elses rather nasty rats nest up, so I spread it out over a couple days..that being said, when i actually got to work on the PAC side, it took me about 4-6 hours too, with some help from Julio and people who could solder...LOL
I was very anal with my install and was also new with a solder gun. I took my time and it only took me about 4 hours to install. After you get it all together you just drive around with a big stupid grin on your face every time you see 20lbs of boost and ZERO knock on the scanmaster. The best investment I have bought for my car. Julio's product is amazing but the customer service is 10 times better. Have fun it is unbelievable.
Combine the alky kit with a Turbotweak alky specific chip and you have a completely different animal sitting in your garage.
Hopefully you guys can help, I'm in the middle of installing Razors kit, I've mounted the pump to the bumper bracket, but the feed line from the alky tank won't reach :( . Maybe I'm routing it wrong... I dunno. Any help is greatly appreciated. Also, any input on where you've mounted the overflow tank would be great. Thanks in advance ;)
You sure you're running the correct line? I attached the lines to the pump before I mounted it... take it back out... there's one line straight to the tank and two lines going to the up pipe...
bigger line from the alchy tank mounted on the passenger side right? smaller line from the pump to the in line filter then last line to up pipe...recheck... let us know
call me if you have a quest 808 223 3464
The install pic confused me a bit.
The hose fittings go on top - not on the bottom.
That also means the bumper bolt fittings might be on the wrong side the way you possibly have it now.
Patience.
It's more than worth it.
Paul
The hose fittings go on top? Maybe thats my problem :rolleyes: . I'll try and work on it some more this evening and let you know. Thanks again.
Yup ;)
And you can call during regular hours if you get into a jam..
Julio
