Ok ive got the NX kit ready to install now heres the deal . I plan on running it only with c16 which is coming from a sumped 10gal cell through a paxton pump into AN8 to the rail . Now im planning on spraying a 75 shot through the 1/4 with boost set @ 16 pre nitrous so with the juice it should go up to 19-21 lbs max . The real ??? is could i use the Reds chip w/ 21deg timming ive got or should i go lower . Also Bottle heaters i assume im going to need that for N.Y weather anything other than summer and lastly nitrous filter a need or not . Ive got a purge with the kit. Any one that want to chime in with bottle pressures for best perf. , Jet sizes or whatever . Thanks
