- Aug 1, 2003
i still dont get it and im loosing IQ points as i read your posts
SignUp Now!There is another item that will not allow the car to start,the 3 bar map
If it has fuel pressure , and it has spark.. It's got to run.
turnon should be a few degrees above the thermostat opening temp...theres no reason to run a fan when coolant isnt circulating
HelloBozos said:We figuered it out....It was how the Alky power green wire was ran into the foamed over connector in the glovebox, The connector's wiring was loose, so when any heat or jolts (like when you shut the door that time) it would short out an take the Map Sensor with-it. With the car running if you shook the connector the car would stall. It was funny becuase you could take the map sensor it's wired to an shake-it in certin rythum an you could make the car Lope on the cam but pig rich,shake to hard, motor dies.
Before with the problem...
Cal took it out an ran it differant way now an the car runs for ever now...Whew!!!
Still thank you for coming out that day, there was alot other thing you did fix.
(now my smartarse comment, i knew i'd get bit in the arse having a Ford guy work on my Buick again...hehehe) 8^)
bison said:A data log of this occurring would have answered this long ago.
Yeah.. but it requires a working computer hooked up and recording at the exact time that it happens. Some things are meant to be tougher to find. When I was there few months ago and this happened that the car wouldnt start.. things appeared normal.. but who knows..A data log of this occurring would have answered this long ago.
