Apr 7, 2006 #1 D dvernst Well-Known Member Joined Jan 9, 2006 Messages 1,879 Where have you guys mounted the solenoid for the boost controller? I mounted mine on the same bolt that holds the factory one, but I don't know if it gets too hot there. The instructions to install it somewhere where it will stay cool?
Apr 7, 2006 #2 W WeSS I gotz 2 sub woofers Joined Apr 14, 2004 Messages 2,415 huh? just an idea but maybe on the firewall. You know where some people put their aftermarket injector harness relays at. Maybe a cooler spot.
Apr 7, 2006 #3 J jdsgnx Well-Known Member Joined Mar 2, 2002 Messages 5,302 Works fine on valve cover , just keepwires away from intake!! thanks JD
Apr 7, 2006 #4 D dvernst Well-Known Member Joined Jan 9, 2006 Messages 1,879 O.k. yeah I routed the wires arond the front of the intake. I tucked it in to a some wire loom that was already there. Thanks
